Hello
I like to comment the Registration table so I can see who is what but on RouterOS “feature is not implemented”
I am using winbox.
Is there another way to do this?
Thanks ![]()
Hello
I am using winbox.
Thanks ![]()
well the entries in that table are completely dynamic. your wireless client could be gone in the next second and never to return. comments would be useless in this list. the comment, however, could appear if you have this client in the access list. in this case, set your comments in the access list page. we will disable that button to avoid confusion
OK Great, Thanks, That makes more sence ![]()
