comment in export for broken reference
RouterOS configuration works with referencing configuration items. Things break when an item is removed and reference points to a non-existent id:
[admin@ros7] > /interface/bridge/add name=test
[admin@ros7] > /ip/address/add address=10.0.0.1/24 interface=test
[admin@ros7] > /interface/bridge/remove test
[admin@ros7] > /ip/address/print
Flags: I, D - DYNAMIC
Columns: ADDRESS, NETWORK, INTERFACE
ADDRESS NETWORK INTERFACE
0 D 10.7.7.159/24 10.7.7.0 bridge
1 I 10.0.0.1/24 10.0.0.0 *B
When printing the configuration you see the dangling id (*B in this case). However exporting the configuration you can not see this:
[admin@ros7] > /ip/address/export
add address=10.0.0.1/24 network=10.0.0.0
In case of broken references I would like to see a comment in export showing the issue, something like:
# WARNING: broken reference to internal id *B
I contacted support (SUP-58120) an their answer was:
Thank you for your request, if there will be more, similar request like yours, we will see how this can be added in the future versions.
So if you think this would be a good addition please cast your vote by opening a support ticket.
Is not a 7 prerogative, also on 6 the same:
pri
0 I 6.6.6.6/24 6.6.6.0 *B
export
add address=6.6.6.6/24 network=6.6.6.0
Yes, it is the same there. As active development moved to v7 and my examples use new syntax I decided to post here.
I think it would be better if the export for ip address followed the same rule as for bridge port: export interface ID instead of omitting interface attribute.
[admin@MikroTik] > /interface bridge port export
# sep/22/2021 09:00:35 by RouterOS 7.1rc4
add bridge=docker interface=veth1
[admin@MikroTik] > /interface veth remove veth1
# sep/22/2021 09:01:37 by RouterOS 7.1rc4
add bridge=docker interface=*E
Fine with me… Thought searching for the comment should be easier.
But there should be a way to detect broken reference in export. Just silently ignoring is the wrong way.
