Comment on Manual:Create Certificates
I have ROS v5.12 on a RB750GL.
I followed the steps indicated in http://wiki.mikrotik.com/wiki/Manual:Create_Certificates.
I then associated the certificate with the www-ssl service in /ip service
No matter what I did, the www-ssl service continued to be marked as invalid.
After a reboot of the router, the www-ssl service was OK!
I dont know if this
  • 1)is my config problem
  1. a bug in ROS v5.12, or
    3)this is the way that it must be in which case the Manual should be updated to say do a reboot.
