Comments and other Enquiry
Hello Folks
I am restarted looking at mikrotik after years.
Got RB3011UIAS running V7.16.1 Firmware and Packages - Standard Level 5 License
Winbox 64bit v3.41 + Winbox 4.0 beta 12
I got question in regards to comments -
When router adds a dynamic ip to iP>>Firewall>>Address list
I notice one cannot add comments to “tag” identify to the address
Just enquiry if it may be a bug or not?
IP->>POOL
Add Show colums does not show Comment columns.. to show..
However once you do inline comments the comments does show
OTHER
IP>>CLOUD>> BTH VPN
All the entries of it seems cannot been modified.
IP>>Firewall - Firewall (Placement can however move)
IP>>Address
IP>>Routes
Interface>> (Seem can rename basic name)
Need advise on my internal issue :
I got a metrofibre PUBLIC IP however router shows i am behind a NAT.
How can i use services as i am blocked even if i have enabled Port Forwarding to (Manual Static DHCP Lease) and selected the port forward on 22,8291,35327 (tcp and udp) and 9993 - WAN has ports accepted.
Back to Home only seems to work for me if Running it off from the SAME network (Local),
However with ZeroTier (From Local And WAN + 3g) i am able to login to router via IP (mac however not working)
ZeroTier has Bridging Enabled
Well here is the scoop to use wireguard NORMAL, manual config, or port forwarding for that matter you need
a. a public IP address
OR
b. an upstream router/modem, usually the iSP one, with a public IP AND the ability to forward ports.
If you have the above then you dont need to use BTH.
If you do not have the above then use BTH.
The IP CLOUD BTH menu you speak of is not changeable but simply for awareness/viewing. → BTH VPN
The other tab is BTH VPN Wireguard and it looks like this is used to generate a single BTH setup for a client.
(at the router can only make one).
To make multiple QR codes, one has to first set it up on the Admin smartphone and then use Manage Shares from the phone to add multiple users.
Now look at the far right column there are a few selections with OK at the top and Back to Home Users at the bottom.
This is where you can make changes…
My interpretation on how the thing works…so may not be 100% correct.
