My goal: 2meg download and 1meg upload using PCQ
My problem: Upload speed for clients on local side is never correct. Usually I have to adjust it to double to get the correct bandwidth. You will see that in the “Queue Type” below. This is not being caused because of a shortage of available BW.
My download speed though is always reasonably close.
I have tried multiple different PCQ setups and all have the same problem. Here I have a very simple configuration so someone can help diagnose the problem.
System:
RB450G V3.30
Ether1 15meg public symmetrical connection
Ether2 Local Network, DHCP server, NAT, Mangle, Queues, Firewall, etc.
Ether3 is a switch using ether2 as a master
Ether2 and 3 are connected to AP’s
My example here will be to cover all IP’s /24 on the local side with the exception of a few using address list entries. There is over 100 clients.
- First mark all connections and all packets using mangle (there is no other mangle entries)
/ip firewall mangle
;;; Add 2meg Connection Marks
chain=forward action=mark-connection new-connection-mark=2meg-conn passthrough=yes src-address-list=!do-not-queue
;;; Add 2meg packet marks
chain=forward action=mark-packet new-packet-mark=2meg_traffic passthrough=no connection-mark=2meg-conn
- Setup Queue types (notice my up speed is set to over 2meg, but all clients get .8 or .9meg while download speeds work correctly)
/queue type
name="PCQ_down_2M" kind=pcq pcq-rate=2200000 pcq-limit=50 pcq-classifier=dst-address pcq-total-limit=7000
name="PCQ_up_1M" kind=pcq pcq-rate=2200000 pcq-limit=40 pcq-classifier=src-address pcq-total-limit=4000
- Queue Tree
[admin@Main] /queue tree> print
0 name="Total_Download" parent=ether2 limit-at=0 priority=1 max-limit=15M burst-limit=0 burst-threshold=0 burst-time=0s
1 name="Total_Upload" parent=ether1 limit-at=0 priority=1 max-limit=8M burst-limit=0 burst-threshold=0 burst-time=0s
2 name="2_meg" parent=Total_Download packet-mark=2meg_traffic limit-at=0 queue=PCQ_down_2M priority=4 max-limit=0
3 name="2meg_client" parent=Total_Upload packet-mark=2meg_traffic limit-at=0 queue=PCQ_up_1M priority=4 max-limit=0
