communication
How can I communicate with the serial port as I am having a bid demand to convert allot of rs232 and 485 system has anyone thought of adding a app to the router board to communicate with the serial port
Something like HyperTerminal and a way to pull off the data maybe something like log print
Or a program that works like HyperTerminal but over ip to the boards serial
Example pc-----rb---------wireless---------------wireless-----rb-serial rs232 coms
Program can read the info if you add in the rb ip address/serial0
you can assign a special-login to attach to the serial port when you telnet / ssh in using that login. Then you will be connected to serial port after entering user/password.
Lantronix makes lots of little inexpensive boxes for transferring serial data over IP networks too.
jp is right, there are serial over IP devices.
Perhaps you could write your own app to use the built-in serial port, but it’s not the simplest solution.
I remember Orinoco’s Ethernet & Serial converters from about 10 years ago.
ORiNOCO/EC-S
It only does 802.11b with WEP and no WPA, but it should allow you to telnet from the pc to serial port of the unit.
I have used some of the non-serial units with just a single PC connected to the Ethernet Converter but haven’t used the serial units.
You should get better results with a routerboard and an terminal adapter like jp suggested.
well with time i got it right to just use the board no need for converters so no extra expence
less problems with extra equipment easy to mange
does any one know if mikrotik does 485?
on the serial port
