Hi all,
I installed a 1GB compact flash on RB500 but it is not recognized.
Has anyone encountered the same problem?
thanks in advance.
Hi all,
thanks in advance.
you are aware that it will only work as a proxy cache drive? you should have it available in the menu “/ip proxy format-drive”
