Company router EDITED
Hi everybody
my setup is:
rb493g where
ether1 192.168.1.254 1st department
ether2 192.168.2.254 2nd department
ether8 isp1
ether9 isp2
I need to setup the router for load balance and failover so:
192.168.1.0/24 uses gw on ether8, if it fails then ether9 and
192.168.2.0/24 uses gw on ether9, if it fails then ether8 and
the both subnets see eatch other
I have been following this tutorial
http://wiki.mikrotik.com/wiki/Advanced_Routing_Failover_without_Scripting
It is not working for me
add dst-address=8.8.8.8 gateway=109.x.x.x scope=10
add dst-address=209.85.227.103 gateway=109.x.x.x scope=10
add dst-address=209.85.227.147 gateway=182.x.x.x scope=10
add dst-address=74.125.230.152 gateway=182.x.x.x scope=10
add dst-address=10.1.1.1 gateway=8.8.8.8 scope=10 target-scope=10 check-gateway=ping
add dst-address=10.1.1.1 gateway=209.85.227.103 scope=10 target-scope=10 check-gateway=ping
add dst-address=10.2.2.2 gateway=209.85.227.147 scope=10 target-scope=10 check-gateway=ping
add dst-address=10.2.2.2 gateway=74.125.230.152 scope=10 target-scope=10 check-gateway=ping
add distance=1 gateway=10.1.1.1 routing-mark=ISP1
add distance=2 gateway=10.2.2.2 routing-mark=ISP1
add distance=1 gateway=10.2.2.2 routing-mark=ISP2
add distance=2 gateway=10.1.1.1 routing-mark=ISP2
there are no other routes or gateways, it says reachable but I can not ping outside
Can somebody tell me what I am doing wrong and what are my options?
What do you mean by not seeing each other? In that setup both networks should be able to reach each other on Layer3.
well they see eatch other, but they cannot go out to internet
