Comparing internal IDs
Faced with a strange issue today.
:global LastID [:toid *1b]
:local testID [:toid *5]
:if ($testID > $LastID) do={
    :set LastID $testID
    :log info "Last ID updated"
Tried to compare 2 internal IDs and got this error:
Script Error: cannot compare if array is more than array
I don't even understand the meaning of this message. Am I doing something wrong or it's a bug that should be reported?
:foreach item in=[find where (((([$id2num $".id"] > $lastLog) and [...]
I solved the problem myself time ago with $id2num
:local id2num do={:return [:tonum "0x$[:pick $1 1 [:len $1]]"]}
For me is a bug.
Working example:
    :if ([$id2num $testID] > [$id2num $LastID]) do={
        :set LastID $testID
Yeah, also started doing this via conversions.
Will report to support.
