Compatibility of Netmetal with CPE
We are installing Netmetal - 5 - RB921UAGS-5SHPacD-NM with UBNT AC Sector (60 degree) on a 30 meter tower . So total there will be 6 sectors and 6 radios. We will be connecting max 35-40 users per sector.
Now, suggest me list of CPEs supported by this BTS other than SXT Lite 5 and SXT AC. Actually I’m looking for low cost CPEs without compromising performance.
Also, how many simultaneous users can be connected per radio? Any suggestions?
Thanks.
Interesting!!!. We’ve tried this configuration a month ago and we can’t connect sxt lite 5 (A/N NOT AC) with Netmetal 5 AC (exact model you’ve said).
When using 802.11 protocol, it refused to connect saying " "
When using nv2 protocol it allows to connect clients (all are sxt lite 5 A/N) but all of them are 6 Mbps/6 Mbps and digging a little further, AP says it is in “Alignment-only” mode. NM5AC are configured in AP Bridge with Dynamic-Mesh and a Bridge assigned to it.
When using nstreame proto, it refused to connect sayint "invalid ".
I’ve used all of three wireless packages. wireless-fp, wireless-cm2, wireless-rep.
routerOS version is: 6.35r49 (tried every 6.x version!!).
Default Authenticate are enabled and Default Forward as well.
I guess it is not a configuration problem but a firmware one.
I’ve upgraded near all my net with ac products like
RB921UAGS-5SHPacD-NM and RB922UAGS-5HPacD-NM + R11e-5HacD
and all is working flawlessy with CPE from RB411+R52 to QRT 5
I do not use WDS.
why on proprietary extension you have pre-2.9.25???
After some upgrades, I’ve also found some of my AP’s with pre-2.9.25 …
