I consider these 4 requirements are quite common and even necessary (as in case of PIN validation and AT commands), but none of the modems listed on ‘Supported Hardware’ section meets those requirements.
The minimum speed: DL-7Mb, UL-2Mb (HSPDA, HSPUA)
Modem Format: miniPCI express
PIN code validation.
Data Channel and Info Channel must be different in order to query some info params via AT commands once connection is established.
Currently Sierra Wireless is the only manufacturer which provides models meeting those requirements, but they are not fully compatible with ROS (validating PIN).
It would be great and almost necessary to add support to ROS firmware for compatibility with Sierra Wireless devices, or ask Sierra Wireless to collaborate with Mikrotik development team to make Sierra devices work correctly.
In case collaboration betwen Sierra Wireless and Mikrotik were not possible, I would appreciate any advice to solve this issue.
Hello.
We acquired a Sierra Wireless modem MC8792V. We did the tests and the result - The modem does not support validation PIN code via Data-channel. Neither this nor any.
We have a collection of modems (about 800 euros loss), we are buying to see that are not compatible with ROS. Although the page http://wiki.mikrotik.com/wiki/Supported_Hardware#3G_cards indicates that they are all compatible.
They are only compatible if you disable the PIN-code, but this does not work for industrial environments, for company that has distributed hundreds of devices.. Sure, if you play at home.
Exactly. His answer was - your modem are not compatible.
I just buy another modem MC8792V. It works the same.
And we had about 6 others from this list - work the same.
Sierra Wireless MC5720
Sierra Wireless MC5725
Sierra Wireless MC8705
Sierra Wireless MC8755
Sierra Wireless MC8765
Sierra Wireless MC8775
Sierra Wireless MC8780
Sierra Wireless MC5727
Sierra Wireless MC8785
Sierra Wireless MC8790
Sierra Wireless MC8792
Sierra Wireless MC8781
Access via SSH and Winbox for our RB411U is enabled.
