I am looking for a list of compatible hardware with ROS 4.3 , I purched a license before ( version 3.1) and now I am going to upgrade to ROS 4.3
is Gigabyte MA87LM-S2 compatible with ROS 4.3 ?
is RTL8111 (On board lan card) compatible with ROS 4.3 ?
Regard
normis
December 3, 2009, 9:03am
2
A user compiled list is here:
http://wiki.mikrotik.com/wiki/Supported_Hardware
you can also search this forum
I seen that list, but I did not find any information about ROS 4.3
all of users post about version 3.x
Mikrotik ROS is excellent , but It don’t have a good manual about compatible hardwares.
An important question :
I installed ROS on a AMD Pc. after one year I replaced the motherborad and now ROS still show the old driver and hardware configuration.
How can i define the new hardware ( link ether card) in ROS ?
do it have a auto detect tool ?
regard
normis
December 3, 2009, 9:38am
5
I don’t understand what you mean? What old hardware information? The only important thing is that your interfaces all work fine, it doesn’t matter what is written somewhere.
Intel 82575EB & 8257GB
What do you mean?
my problem is :
after I swap the motherboard of the routerPC, ROS do not detect the new hardware like on-board Ethernet card.
the new motherboard is : Gigabyte MA87LM-S2
and it’s on board Lan card is : RTL8111 gigabit
I don’t know how can I define this new hardware on ROS.
my ROS version is 4.3
Regard
