Which is a compatible outdoor AP that the RB2011-UiAS-2HnD-IN PoE can handle without injector?
The router PoE should support 500mA as the technical PDF says.
Doing two calculations with 24V, I assume it can support device up to 12W, right?
The GrooveA 52HPn should absorb 4W so it is ok, but the Metal 2SHPn says 14W, so I have to assume that it is not supported?
I would like someone who could clarify my calculations, thanks.
