Hello
I would like to install a COMPEX WLE600VX miniPCIe on RB912UAG-2HPnD.
Anyone has ever tested the setup?
Any suggestion for a 2-port dual-band directional antenna?
Andrea
Card is OK. We are using Cyberbajt anntenas with them.
Thanks for the feedback.
I assume you use SA 2456 xxx antennas, which are the only dual band antennas available in Cyberbajt’s catalog.
Question: those antennas have two connectors, one for 2.4 and one for 5 Ghz, right?
If so you use only one chain of the WLE600VX card. Am I mistaking?
My idea was more to have one dual-band antenna that can fully leverage the dual chain capability of the COMPEX card.
the main need is not to tx/rx signals on both bands at the same time, that’s not required.
I am looking for a 2x2 MIMO dual-band antenna with only two dual-band connectors
input 1 for 2.4/5 Ghz V pol to connect COMPEX card chain 0
input 2 for 2.4/5 Ghz H pol to connect COMPEX card chain 1
I only find 2x2 dual-band antennas with 4 connectors.
Thanks for helping me…
