I apologize if this thread is in the wrong place or like other forums, it’s frowned to simply post questions but I am at a complete loss. I have googled, I’ve used the search features and I found things similar to what I am trying to do, but either I am a complete failure at reading the directories or it’s just different enough that I cannot get it to work.
I’ll start with the short story and see if anyone has follow-up questions to help guide me. I don’t mind being told to RTFM, but please at least link me to the manual because even parts of that were hard to find.
So about 2 years ago I bought a basic: http://routerboard.com/RB2011UiAS-2HnD-IN for my home network. Nothing fancy, I have 5 devices hard-wired into it and maybe another 5-6 tablet’s/phones that connect via wifi. I was able to set this up as a basic home router which is connected to standard comcast cable modem. Nothing fancy at all and I’ve had no problems.
Fast-forward to now and I noticed that depending on where I am in the backyard, the wifi signal begins to weaken. This is not completely unexpected, I get it. However moving the router is not really an option since the entire house is wire and configured in such a way that it’s just not possible. Plus I don’t mind spending a little bit of money to achieve a desired goal. So I do what little pathetic research I am capable of and I was determined to stick with routerboard because I love the current router I have(went to it after having issues with 3 different linksys/netgear ones) and I find this little gem: http://routerboard.com/RBSXT5nDr2
Perhaps I didn’t read up properly or I am misunderstanding some basic network concepts but I got the impression that I could mount that outside and aim in the backyard where I was my signal. Well, the physical mounting was easy. But I just cannot get the damn thing to work.
It is physically wired into the existing router via ethernet cable. If I log into the SXT5 via WinBox I can set it to routermode, give it a unique SSID and then I can see it in the yard. However I cannot set it to AP_BRIDGE because I do have the license, and based on this portion of the manual that is what I need to set it to: http://wiki.mikrotik.com/wiki/Manual:Interface/Wireless#General_interface_properties
So my question: Is it possible to set this thing up in the backyard so it basically acts as a router? Allowing any who have a good signal to connect and surf the web no different than if they were on my couch? If so how do I do that? I’m happy to go through some heavy reading or whatever but all I could find were a bunch of articles on bridging…which if i understand things correctly is not quite what I am looking for. I don’t want to link me and the neighbor, I just want to extend my own wifi-range. Did I buy the wrong product?
Lastly, and this would be a minor concern. Is there a way to have my router and this device use the same SSID so the connection/transfer would be seamless to someone walking from say the kitchen to the backyard? It would just automatically start sending via the SXT5 instead of the router? That’s my perfect world but I’d settle for two different SSID’s
I really appreciate any help.
-Mark
