I have unusual issue. I unfortunatelly blocked access to production mikrotik at my work. I disabled web access and added wrong firewall rule to drop traffic - which results in cutting me off my device. Can someone help me with accessing and to disable/remove DROP rule on firewall ?
My internal network is 10.80.0.0/24 and the gateway is 10.80.0.1 which I cannot SSH neither Telnet… I allowed ICMP so I can ping gateway and the Internet traffic works fine, except I cannot get in.
What to do when I directly connect my laptop to the mikrotik and I open the Winbox click: […] to open connections and I have empty tables (completely blank) without any MAC addresses?
Did you try to connect both from Ether2,3,4,5 and also the WiFi AP side? You can try to manually enter the MAC address as well, if winbox doesn’t detect it
Yes. The problem is that I am connected via ethernet cable to port 3rd to the Mikrotik + I am already connected via Wifi to the same MikroTik - scan shows nothing…
Is it possible that some ether ports are not enable to login via MAC address to the Winbox?
Is it possible to completely block even MAC access to the router ? (the last rule in the firewall I set is to DROP ALL )
firewall does not affect the MAC level access, only IP level access.
but a separate configuration menu exists to block MAC level access as well, maybe you blocked it there before:
In any case. If MAC access does not work from any interface (I know you only tried Ether3, but if this is important, you should unplug somebody and try the other ports at some point), then reinstall or reset is the only choice.
