Hi, What I want is:
I’m using Mikrotik 2.9.x
I want it to create a .txt file in every 6 hours. File should be named as a ‘date’ and hour name.
Also, I want to
log print file thatdateandhour.txt
That command will be work in every 6 hours. That should use same file as mikrotik create that .txt file.
How can I do that?
fosben
October 15, 2008, 12:33am
2
sorry, cant test this code in 2.9.x I made it in 3.14..
:local varDate;
:local varMonth;
:local varDay;
:local varYear;
:set varDate [/system clock get date];
:set varMonth [:pick $varDate 0 3];
:set varDay [:pick $varDate 4 6];
:set varYear [:pick $varDate 7 11];
log print append file=([$varMonth]."-".[$varDay]."-".[$varYear]."-".[/system clock get time])
This script wil print log to a file with filename month-day-year-time.txt
Schedule it to run every 6 hour and youre done.
I had to format the date strings or it wouldnt be accepted as a file name because of the /'s
fosben:
:local varDate;
:local varMonth;
:local varDay;
:local varYear;
There’s no code like log print append file in mt 2.9.x I guess so I made it:
:local varDate;
:local varMonth;
:local varDay;
:local varYear;
log print file=([$varMonth]."-".[$varDay]."-".[$varYear]."-".[/system clock get time])
Guess It will no make problem.
I clicked Run Script.
It didn’t create a file.
When I try the script that I give, There’s a number adding in ‘Run Count’
but when I clicked your script, there’s no number adding in Run Count so it always has been 0.
fosben
October 15, 2008, 4:37pm
4
this should work (but only gives you a timestamp on the file)
-this is the only code you need, remove the rest
log print file=([/system clock get time])
[admin@MikroTik] > :local varDate;
[admin@MikroTik] > :local varMonth;
[admin@MikroTik] > :local varDay;
[admin@MikroTik] > :local varYear;
[admin@MikroTik] > :set varDate [/system clock get date];
[admin@MikroTik] > :set varMonth [:pick $varDate 0 3];
[admin@MikroTik] > :set varDay [:pick $varDate 4 6];
[admin@MikroTik] > :set varYear [:pick $varDate 7 11];
[admin@MikroTik] > log print file=([$varMonth]."-".[$varDay]."-".[$varYear]."-".
invalid expression
this is mine
[admin@MikroTik] > log print append file=([$varMonth]."-".[$varDay]."-".[$varYea
invalid expression
no such argument (append)
this is yours.
fosben
October 16, 2008, 10:58am
6
yes I know… use the line in my previous post.
fosben:
It just saves the time. I need also date.
mrz
October 16, 2008, 3:22pm
8
You will not be able to use date in format as ‘/system clock get date’ is giving it out as file name ( / symbol is not allowed in filenames).
You have to replace all ‘/’ symbols with, for example ‘-’.
elgen
January 19, 2009, 9:55pm
9
try this. I tested it, it works.
:global thisdate [/system clock get date]
:global thistime [/system clock get time]
:global datetimestring ([:pick $thisdate 7 11] . [:pick $thisdate 0 3] . [:pick $thisdate 4 6] . “-” . [:pick $thistime 0 8])
/log print file $datetimestring
