compression=yes in ppp profile
Hi folks!
hoping you are doing well! I’m struggling on trying to use the compression=yes settins while setin up a ptp between 2 mikrotik router.
I tried this using pptp, l2tp and pppoe without detecting any improvement..
My open questions are :
  1. under ppp profile , compression=yes what willreally do?
  2. is it available for all kind of ptp or just for a subset of them?
  3. how can I enable successfully it?
  4. is this compression related to MPPC ?
My test are based on trying to send a file using the ptp and to verify the difference beteween having compressed = yes or comrpessed = no.
I also tried it enabling or disabling use-encryption. without any success.
The RoS used for test is 6.1
please let support me clarify this.
