comunicate with deom one network to another
i am using rb3011as a switch so i can manage the network on which i have given a static public ip to access it from remote i also made vpn to connect but i cant access the local network from that vpn
ether1 is wan
and ether2-10 is on bridge1
i want to access from wan to bridge1 using vpn
Please provide a network diagram as I do not understand what you are trying to do.
The switch is very easy to setup (minimal config).
Bridge for all connected ports
Vlans carry the data from the incoming trunk port to outgoing access ports (dumb devices) or other trunk ports (to smart devices).
