I have the variable $hello with the content 123
I want to define a variable whose name is the content of $hello + 456
if I did a put it would be :put $hello+123
the name of the final variable should be :123456
Is it possible? How is it done?
But this is not what OP ask: concatenate variable names
Your example is not concatenate variable names, but concatenate values…
Is better define the problem: Define a variable whose name is the concatenation of the content of another two variables parts.
And the solution is: change mind and use one array.
I do not use 123 on example for avoid confusion on variable name that is one number.
:local variables {“hello”=“abc”}
:put “current content of hello variable is >$($variables->“hello”)<”
:local newvarname (($variables->“hello”) . “456”)
:put “new variable name is >$newvarname<”
:set ($variables->$newvarname) “test”
:put “value of >$newvarname< is >$($variables->$newvarname)<”
Results:
current content of hello variable is >abc<
new variable name is >abc456<
value of >abc456< is >test<
Typical error. Asking how to solve brainfart instead of describing the problem to solve and get the real solution.
We don’t know what OP wants to solve, but i suspect that a classical hashmap is what OP want.
Well I'm not sure OP was very clear. String interpolation get's tricky with variables and numbers... i.e. "$($var123)456" syntax isn't entirely obvious too.
Maybe OP did not hear for key-value arrays (maps/dictionaries) where to some dynamically created key (identifier) some value can be assigned, only logic I can think of for such request…
For do the same with a variable called 123456 (ignoring the : that is a typo for sure…)
:local variables {“hello”=“123”}
current content of hello variable is >123<
new variable name is >123456<
value of >123456< is >test<
As I already write: I do not use 123 on example for avoid confusion on variable name that is one number.
