Hi - hAP be lite with ROS 24.4
Perhaps trying to be too ambitious, but hoping to:
- Dual-band AP (SSID on both 2.4 + 5 GHz)
- Simultaneously run one or more Station interfaces on the 5 GHz radio for WAN failover
This is how it goes:
- Without an MLD interface the radios stay inactive with the message mld-interface missing or not MLD
- Once I create an MLD interface and assign both wifi1 + wifi2 to it, the radios become active and work well as APs.
- As soon as I create virtual interfaces in station mode on wifi2 (which is part of the MLD), those station interfaces remain permanently Inactive (Bound but not Running).
- The system also shows the message: "mld-interface only supports AP mode"
Questions:
Maybe I'm doing something wrong, or....
- Is concurrent AP + Station mode supported on the same radio when using MLD on wifi-mediatek?
- Is this a limitation of the driver that might be worked out in a future release?
- Or is pure concurrent AP+Station (without MLD) supposed to work, and the forced MLD behaviour is a bug?
Thanks!!
