concurrent users
I have rb750gl and designed hotspot with max 100 concurrent users I dot no how session will be have,
Can I install user manager in same box for print ticket or the user manager restricts concurrent user and session ?
What happen with license and concurrent user ?
Plays a role if users is shared user with same user name and pass ??
If user manager restricts concurrent user or active session, there is any else method to print ticket with user name and pass in thermal printer ??
Thx
Br
  1. yes you can limit user logons to just 1 active machine(ip address). e.g trying to logon on another machine with currently running session will result in simultaneous user session reached error on the logon on the second machine…
  2. Dont use a 750gl with a level 4 licence as you will only be allowed to have a maximum of 20 of your users active(usermanager limitation, not a limit on the hotspot itself) at any one point in time, you will need to upgrade the units licence to a l5 or l6 licence. Or just buy a 1200 series with l6 intergrated! or better still 1100ahx2 with micro sd slot for storage expansion..
  3. if you still go down the path of the 750gl as a hotspot with l4 licence, then use an external pc(linux is best bet) with a suitable radius package to manage users and allow you to utalize all your level 4 hotspot user capability.
