Hello
I want to know if I can connect a serial device to the router
and them make the router and the device “talk” ?
let say I connect a serial GPS -can I write a script that display me the GPS status as a warning log?
Thanks ,
Hello
Thanks ,
Yes you can make use of the serial port in a number of ways -
GPS on a Mikrotik router -
http://wiki.mikrotik.com/wiki/Manual:System/GPS
Serial Port usage -
http://wiki.mikrotik.com/wiki/Serial_Port_Usage
You can even use the port as a redirected comm port connected to your PC.
this one isn’t good for what I need
this talk about connecting a gps using USB
I want to connect it to the Serial of the RB
I will try to read and work according to
and see if it works
I think you’ll find it supports Serial
port (string; Default: ) Name of the USB/Serial port where GPS receiver is connected
