Hello everyone,
This is my example topo, Load balancing 2 Wan and 1 Bridge Lan. I had config already to work ok.
This is my example config:
add comment=LAN name=bridge1-LAN
set [ find default-name=ether1 ] comment=WAN1-7Mbps speed=100Mbps
set [ find default-name=ether2 ] comment=WAN2-3Mbps speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] comment=bridge1-LAN speed=100Mbps
set [ find default-name=ether6 ] comment=bridge1-LAN speed=100Mbps
set [ find default-name=ether7 ] speed=100Mbps
set [ find default-name=ether8 ] speed=100Mbps
set [ find default-name=ether9 ] speed=100Mbps
set [ find default-name=ether10 ] speed=100Mbps
set [ find default-name=ether11 ] comment=Manage speed=100Mbps
set [ find default-name=ether12 ] speed=100Mbps
set [ find default-name=sfp1 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=sfp2 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=sfp3 ] advertise=10M-full,100M-full,1000M-full
set [ find default-name=sfp4 ] advertise=10M-full,100M-full,1000M-full
add name=dhcp_pool0 ranges=192.168.88.2-192.168.88.254
add name=dhcp_pool1 ranges=192.168.50.2-192.168.50.254
add address-pool=dhcp_pool0 disabled=no interface=ether11 lease-time=1h name=\
dhcp1
add address-pool=dhcp_pool1 disabled=no interface=bridge1-LAN lease-time=12h \
name=dhcp2
add bridge=bridge1-LAN hw=no interface=ether5
add bridge=bridge1-LAN hw=no interface=ether6
add address=192.168.88.1/24 comment=defconf interface=ether11 network=\
192.168.88.0
add address=1.1.1.2/30 interface=ether1 network=1.1.1.0
add address=192.168.0.2/24 interface=ether2 network=192.168.0.0
add address=192.168.50.1/24 interface=bridge1-LAN network=192.168.50.0
add address=192.168.50.0/24 gateway=192.168.50.1
add address=192.168.88.0/24 dns-server=192.168.88.1,8.8.8.8 gateway=\
192.168.88.1
set servers=8.8.8.8,8.8.4.4
/ip firewall mangle
add action=mark-connection chain=prerouting connection-mark=no-mark \
dst-address-type=!local in-interface=bridge1-LAN new-connection-mark=\
mark01 passthrough=yes per-connection-classifier=\
both-addresses-and-ports:2/0
mark02 passthrough=yes per-connection-classifier=\
both-addresses-and-ports:2/1
in-interface=ether1 new-connection-mark=mark01 passthrough=yes
in-interface=ether2 new-connection-mark=mark02 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=mark01 in-interface=\
bridge1-LAN new-routing-mark=route01 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=mark02 in-interface=\
bridge1-LAN new-routing-mark=route02 passthrough=yes
add action=mark-routing chain=output connection-mark=mark01 new-routing-mark=\
add action=mark-routing chain=output connection-mark=mark02 new-routing-mark=\
add action=masquerade chain=srcnat out-interface=ether2
add check-gateway=ping distance=5 gateway=1.1.1.1 routing-mark=route01
add check-gateway=ping distance=5 gateway=192.168.0.1 routing-mark=route02
add check-gateway=ping distance=10 gateway=192.168.0.1
It had worked ok.
And now, I want to use 2 Block IP Route of ISP to config the Servers.
I don’t know how to config. Please help me! Thank a lot.
