Config/Backup Downloader via SNMP?!
Hello
is there any way to download mikrotiks backup via snmp?
is there any OID for this work?
I use a script on the router to generate an export and backup daily. Then I use a bash script I wrote to download the configs via sftp.
Alternatively you could use a program like Cobian to download the configs.
another way, that dont need more than the router, is to use mikrotik to email the backup.
is it possible download mikrotik backup files with snmp ? (without any scripts)
