I upgraded from 7.2.3 to 7.6 on hap ac^2, and as result my wireguard tunnel config stopped working. Rollback to 7.2.3 solved the problem without any config change. I tried also some versions between those, all resulting in the same problem.
I don’t know if this is a bug or a problem with my configuration of the tunnel or the routing with routing-marks.
Is there anything I can do, that a upgrade is possible without losing my tunnel-conection?
I observed after the upgrade, that the wireguard tunnel is running, but the Rx packet count stays at 0.
Shot description of my setup:
ether1 is connected to the internet, almost all traffic to the internet should go directly through ether1.
Only connections that came though the tunnel or from TCP 192.168.99.2 port 25 (at ether4 / Bridge DMZ) are marked and routed trough the tunnel.
output of the /export command with some unrelated sections removed. On version 7.6 the output is the same (except version number):
# nov/01/2022 12:26:16 by RouterOS 7.2.3
# software id = Y4CQ-DF7G
# model = RBD52G-5HacD2HnD
add name=DMZ
add name=Gast-Wlan
add name=Wlan
add name=solar protocol-mode=none
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment=InternNet
set [ find default-name=ether3 ] comment=Solar
set [ find default-name=ether4 ] comment=DMZ
set [ find default-name=ether5 ] comment=DMZ
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=***.***.***.*** endpoint-port=\
51820 interface=Server-Tunnel persistent-keepalive=10s public-key=\
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n country=germany frequency=auto \
mode=ap-bridge security-profile=******* ssid=****** wps-mode=\
disabled
set [ find default-name=wlan2 ] country=germany mode=ap-bridge \
security-profile=******* ssid=****** wps-mode=disabled
add keepalive-frames=disabled mac-address=BA:69:F4:4D:3B:42 master-interface=\
wlan1 mode=station multicast-buffering=disabled name=LTE-Bridge \
security-profile=****** ssid=****** wds-cost-range=0 \
wds-default-cost=0 wps-mode=disabled
add keepalive-frames=disabled mac-address=BA:69:F4:4D:3B:43 master-interface=\
wlan1 multicast-buffering=disabled name=GastWiFi ssid=******* \
wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
add keepalive-frames=disabled mac-address=BA:69:F4:4D:3B:44 master-interface=\
wlan1 multicast-buffering=disabled name=solar_wlan ssid=solar \
add bridge=Wlan ingress-filtering=no interface=wlan1 multicast-router=\
disabled
add bridge=Wlan ingress-filtering=no interface=wlan2 multicast-router=\
disabled
add bridge=DMZ ingress-filtering=no interface=ether4 multicast-router=\
disabled
add bridge=DMZ ingress-filtering=no interface=ether5 multicast-router=\
disabled
add bridge=Gast-Wlan ingress-filtering=no interface=GastWiFi
add bridge=solar interface=ether3
add bridge=solar interface=solar_wlan
add bridge=solar disabled=yes interface=*16
add address=192.168.1.1/24 interface=ether2 network=192.168.1.0
add address=192.168.2.1/24 interface=Wlan network=192.168.2.0
add address=192.168.3.1/24 interface=Gast-Wlan network=192.168.3.0
add address=192.168.99.1/24 interface=DMZ network=192.168.99.0
add address=192.168.255.2/24 interface=ether1 network=192.168.255.0
add address=192.168.5.1/24 interface=solar network=192.168.5.0
add address=10.10.10.2/24 interface=Server-Tunnel network=10.10.10.0
add action=drop chain=forward disabled=yes dst-port=25 protocol=tcp
add action=drop chain=input comment="Drop invalid Input" connection-state=\
invalid
add action=accept chain=input comment="Accept Established" connection-state=\
established,related,untracked
add action=drop chain=input comment="Drop inbound DNS" dst-port=53 \
in-interface-list=WAN protocol=udp
add action=accept chain=input comment="Accept Input from LANs" \
in-interface-list=LAN
add action=accept chain=input comment="Accept Winbox" dst-port=8291 \
in-interface-list=LAN protocol=tcp
add action=drop chain=input comment="Drop all other Input"
add action=drop chain=forward comment="Drop Invalid Forward" \
connection-state=invalid
add action=fasttrack-connection chain=forward comment="Accept Established" \
connection-state=established,related,untracked disabled=yes hw-offload=\
yes
add action=accept chain=forward comment="Accept Established" \
add action=accept chain=forward comment="Accept LANs->WAN" in-interface-list=\
LAN out-interface-list=WAN
add action=accept chain=forward comment="Allow DNS for LAN" dst-address=\
192.168.99.4 dst-port=53 in-interface-list=LAN protocol=udp
add action=accept chain=forward comment="Accept from InternNet" \
in-interface-list=InternNet
add action=accept chain=forward comment=Mail dst-address=192.168.99.2 \
dst-port=25,143,587 protocol=tcp
add action=accept chain=forward comment="Webserver RPi4" dst-address=\
192.168.99.4 dst-port=80,443 protocol=tcp
add action=accept chain=forward comment="Webserver RPi2" dst-address=\
192.168.99.2 dst-port=80,443 protocol=tcp
add action=accept chain=forward comment="Accept DST-NAT" \
connection-nat-state=dstnat
add action=accept chain=forward comment="allow Solar" disabled=yes \
in-interface=solar out-interface-list=WAN
add action=drop chain=forward comment="Drop all other forward"
/ip firewall mangle
add action=mark-connection chain=prerouting comment=\
"\DCber Server kommende Verbindung" in-interface=Server-Tunnel \
new-connection-mark=server-tunnel-connection passthrough=yes
add action=mark-connection chain=prerouting comment="Mailserver Outbound" \
connection-state=new dst-port=25 new-connection-mark=\
server-tunnel-connection passthrough=yes protocol=tcp src-address=\
192.168.99.2
add action=change-mss chain=forward comment="MSS Clamping for DSL" new-mss=\
1452 out-interface=ether1 passthrough=yes protocol=tcp tcp-flags=syn \
tcp-mss=1453-65535
add action=change-mss chain=forward comment="MSS Clamping for DSL" \
in-interface=ether1 new-mss=1452 passthrough=yes protocol=tcp tcp-flags=\
syn tcp-mss=1453-65535
add action=change-mss chain=forward comment="MSS Clamping tunnel" \
connection-mark=server-tunnel-connection new-mss=1380 passthrough=yes \
protocol=tcp tcp-flags=syn tcp-mss=1381-65535
add action=mark-routing chain=prerouting connection-mark=\
server-tunnel-connection dst-address=!192.168.0.0/16 new-routing-mark=\
server passthrough=no
add action=mark-routing chain=prerouting new-routing-mark=main passthrough=no
# LTE-Bridge not ready
add action=masquerade chain=srcnat out-interface=LTE-Bridge
add action=dst-nat chain=dstnat comment=Mail dst-port=25,143,587 \
in-interface=ether1 protocol=tcp to-addresses=192.168.99.2
add action=dst-nat chain=dstnat comment=Webserver dst-port=80,443,8448 \
in-interface=ether1 protocol=tcp to-addresses=192.168.99.4
add action=dst-nat chain=dstnat comment="SSH RPi4" dst-port=22 in-interface=\
add action=dst-nat chain=dstnat comment="SSH RPi4" dst-port=2222 \
in-interface=ether1 protocol=tcp to-addresses=192.168.99.2 to-ports=22
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.10.10.1 pref-src=\
"" routing-table=server scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.255.1 \
pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
