Config check - NTP Client and IPv6 issues
My home network I’m also using as a bit of a homelab and have enjoyed using the MikroTik router RB5009UG+S+in I picked up based on this community’s recommendation.
I’m a little more knowledgable on networking than your average Joe, but I’m just a consumer - far less knowledgeable than most of you network experts here!
Here’s the background and issue:
I’ve got a Dual-WAN Failover w/ recursive routing setup that seems to be working correctly.
However, I’m not sure if a recent RouterOS update or me tinkering has seemed to mess up both my NTP Client from picking up the ntp.org servers (stuck in status waiting), and IPv6 seems to not be working correctly. (ping6 www.google.com reports no route to host)
I’d appreciate a config check and any advice you have on fixing and fine-tuning!
# 2025-03-08 15:53:09 by RouterOS 7.18.1
# software id = KT01-24H7
# model = RB5009UG+S+
# serial number = XXXXXXXXXX
add admin-mac=XXXXXXXXXXXXXXXXX auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip kid-control
add fri=6h-21h30m mon=6h-21h30m name=Caleb sat=7h-21h30m sun=7h-21h30m thu=\
    6h-21h30m tue=6h-21h30m wed=6h-21h30m
add fri=5h45m-23h mon=5h45m-22h30m name=Elyse sat=6h-23h sun=6h-22h30m thu=\
    5h45m-22h30m tue=5h45m-22h30m wed=5h45m-22h30m
add name=dhcp_pool1 ranges=192.168.99.220-192.168.99.254
add name="Dahua Pool" ranges=192.168.1.2-192.168.1.254
add address-pool=dhcp_pool1 interface=bridge name=dhcp1
/ipv6 pool
add name=ipv6-xfinity prefix=::/60 prefix-length=64
add name=ipv6-hotspot prefix=2607:fb90::/64 prefix-length=64
/system logging action
set 3 remote=192.168.99.16
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp-sfpplus1
set udp-timeout=10s
/ipv6 settings
set forward=no
add comment="Primary WAN" interface=ether1 list=WAN
add comment="Failover WAN" interface=ether2 list=WAN
/interface ovpn-server server
add mac-address=XXXXXXXXXXXXXXXXXXX name=ovpn-server1
add address=192.168.99.1/24 interface=bridge network=192.168.99.0
/ip dhcp-client
add add-default-route=no comment="Primary WAN - Xfinity" interface=ether1 \
    use-peer-dns=no use-peer-ntp=no
add add-default-route=no comment="Hotspot Backup WAN" interface=ether2 \
add address=192.168.99.0/24 dns-server=192.168.99.5,192.168.99.6 gateway=\
    192.168.99.1 netmask=24
set allow-remote-requests=yes servers=192.168.99.5,192.168.99.6,0.0.0.0
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=jump chain=forward comment="jump to kid-control rules" \
    jump-target=kid-control
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat comment="WAN1: masquerade" ipsec-policy=\
    out,none out-interface=ether1
add action=masquerade chain=srcnat comment="WAN2: masquerade" out-interface=\
    ether2
add action=dst-nat chain=dstnat comment="HyperBackup Vault" dst-port=\
    6281,5007,5008 in-interface=ether1 protocol=tcp to-addresses=\
    192.168.99.16 to-ports=5000-6281
add action=dst-nat chain=dstnat comment=FTP dst-port=21,5002,5003,55536-55899 \
    in-interface=ether1 log=yes protocol=tcp to-addresses=192.168.99.17
/ip ipsec profile
/ip kid-control device
add mac-address=XXXXXXXXXXXXXXXXX name="Elyse iPhone 15" user=Elyse
add mac-address=XXXXXXXXXXXXXXXXX name="Elyse Chromebook" user=Elyse
add mac-address=XXXXXXXXXXXXXXXXXX name="Caleb Acer Chromebook" user=Caleb
add mac-address=XXXXXXXXXXXXXX name="Dell 530 Desktop" user=Elyse
add mac-address=XXXXXXXXXXXXXXXX name="Caleb's iPad" user=Caleb
add mac-address=XXXXXXXXXXXXXXXXXX name="Caleb new Dell Chromebook" user=Caleb
add comment="Monitor External Host Via ISP-1" disabled=no distance=1 \
    dst-address=208.67.222.123/32 gateway=76.XXX.XXX.X routing-table=main \
    scope=10 suppress-hw-offload=no
add comment="Monitor External Host Via ISP-2" disabled=no distance=1 \
    dst-address=208.67.220.123/32 gateway=192.168.1.1 routing-table=main \
add check-gateway=ping comment="Default Route - Main" disabled=no distance=1 \
    dst-address=0.0.0.0/0 gateway=208.67.222.123 routing-table=main \
    suppress-hw-offload=no target-scope=11
add check-gateway=ping comment="Default Route - Backup" disabled=no distance=\
    2 dst-address=0.0.0.0/0 gateway=208.67.220.123 routing-table=main \
/ipv6 address
add advertise=no from-pool=ipv6-dhcp-pool interface=bridge
add address=::1 from-pool=ipv6-dhcp-pool interface=bridge
/ipv6 dhcp-client
add add-default-route=yes comment=WAN1 interface=ether1 pool-name=\
    ipv6-xfinity request=prefix use-peer-dns=no
add add-default-route=yes comment=WAN2 interface=ether2 pool-name=\
    ipv6-hotspot request=prefix use-peer-dns=no
/ipv6 dhcp-server
add interface=bridge name=ipv6-dhcp-server prefix-pool=ipv6-dhcp
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/ipv6 firewall nat
add action=masquerade chain=srcnat out-interface=ether2
/ipv6 nd
set [ find default=yes ] disabled=yes dns=\
    fdaf:XXXX:XXXX:XXXX:XXXX:XXXX:XXXX:XXXX:XXXX \
    hop-limit=64 interface=bridge ra-preference=low
/system clock
set time-zone-name=EST5EDT
/system identity
set name="MikroTik RB5009UG+S+in"
/system logging
set 2 topics=warning,!radvd
add action=remote topics=critical,warning,info,!radvd
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.us.pool.ntp.org
add address=1.us.pool.ntp.org
add address=2.us.pool.ntp.org
add address=3.us.pool.ntp.org
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-interface=ether1,ether4 streaming-enabled=yes streaming-server=\
    192.168.99.150
/ipv6 settings
set forward=no
This might be a problem
Is your basic IPv4 web browsing working correctly? I guess it is.
Please show us:
/system/ntp/client print
And try to ping the servers from your router and maybe a client. Does DNS work for them? What does traceroute show?
faulty ntp is common (for Mikrotik’s).
You often need to src-nat the port from your ntp-client (So it looks like it’s coming from a high port rather than port 123)
As ISP’s, ntp servers will often block ntp from port 123.
Something like:
add action=src-nat chain=srcnat out-interface=WAN1 protocol=udp src-port=123 to-ports=12300-12400
Would be kind of good if a note on this was included in Mikrotik documentation (I have asked)…
