Here’s my config below. Does it look standard? Are the firewall rules in the correct order? Is there some things that could be done to make the port forwarding better?
My goal is to optimize VoIP traffic.
# jun/04/2021 14:27:43 by RouterOS 6.48.2
# software id = 8LB4-7SAS
# model = RB750Gr3
# serial number = xxxxxxxxxxxxxxx
set [ find default-name=ether1 ] comment=WAN1 mac-address=C4:AD:34:72:1D:1A \
name=ether1-WAN1
set [ find default-name=ether2 ] comment=\
"LAN4 (Misc: External devices: Ventilation, etc)" mac-address=\
C4:AD:34:72:1D:1B name=ether2-LAN4
set [ find default-name=ether3 ] comment="LAN3 (FunCo Wifi)" mac-address=\
C4:AD:34:72:1D:1C name=ether3-LAN3
set [ find default-name=ether4 ] comment="LAN2 (FunCo Business)" mac-address=\
C4:AD:34:72:1D:1D name=ether4-LAN2
set [ find default-name=ether5 ] comment="LAN1 (Phones and PBX)" mac-address=\
C4:AD:34:72:1D:1E name=ether5-LAN1
add name=LAN
add name=WAN
add name=dhcp_pool0 ranges=192.168.1.70-192.168.1.254
add name=dhcp_pool5 ranges=192.168.0.70-192.168.0.254
add name=dhcp_pool3 ranges=10.10.3.70-10.10.3.254
add name=dhcp_pool4 ranges=172.18.4.70-172.18.4.254
add address-pool=dhcp_pool0 disabled=no interface=ether4-LAN2 name=dhcp1
add address-pool=dhcp_pool5 interface=ether5-LAN1 name=dhcp2
add address-pool=dhcp_pool3 disabled=no interface=ether3-LAN3 name=dhcp3
add address-pool=dhcp_pool4 disabled=no interface=ether2-LAN4 name=dhcp4
/queue tree
add max-limit=140M name=Upload parent=ether1-WAN1 priority=1 queue=default
add limit-at=15M max-limit=15M name=upload_pri_1 packet-mark=RTP parent=\
Upload priority=1 queue=default
add limit-at=15M max-limit=15M name=upload_pri_2 packet-mark=SIP parent=\
Upload priority=2 queue=default
add max-limit=110M name=upload_pri_8 packet-mark=no-mark parent=Upload queue=\
default
add max-limit=40M name=Download-Phones parent=ether5-LAN1 priority=1 queue=\
default
add limit-at=15M max-limit=15M name=download_pri_1 packet-mark=RTP parent=\
Download-Phones priority=1 queue=default
add limit-at=15M max-limit=15M name=download_pri_2 packet-mark=SIP parent=\
Download-Phones priority=2 queue=default
add limit-at=10M max-limit=10M name=download_pri_5 packet-mark=no-mark \
parent=Download-Phones priority=5 queue=default
add limit-at=95M max-limit=95M name=Download-Business packet-mark=no-mark \
parent=ether4-LAN2 queue=default
add limit-at=5M max-limit=5M name="Download Misc" packet-mark=no-mark parent=\
ether2-LAN4 queue=default
/system logging action
set 1 disk-file-count=4 disk-lines-per-file=4096
add email-start-tls=yes email-to=thisIs@aTest.com name=emailBlocked target=\
email
add interface=ether4-LAN2 list=LAN
add interface=ether5-LAN1 list=LAN
add interface=ether1-WAN1 list=WAN
add interface=ether2-LAN4 list=LAN
add interface=ether3-LAN3 list=LAN
add address=192.168.1.1/24 interface=ether4-LAN2 network=192.168.1.0
add address=192.168.0.1/24 interface=ether5-LAN1 network=192.168.0.0
add address=154.89.111.154/30 interface=ether1-WAN1 network=154.89.111.152
add address=172.18.4.1/24 interface=ether2-LAN4 network=172.18.4.0
add address=10.10.3.1/24 interface=ether3-LAN3 network=10.10.3.0
/ip dhcp-client
add address=10.10.3.0/24 gateway=10.10.3.1
add address=172.18.4.0/24 gateway=172.18.4.1
add address=192.168.0.0/24 gateway=192.168.0.1
add address=192.168.1.0/24 gateway=192.168.1.1
set servers=8.8.8.8,1.1.1.1
established,related,untracked
invalid log=yes log-prefix=Drop_Invalid:
add action=drop chain=input comment="Block MAC e2:b5:74:48:ff:aa" log=yes \
log-prefix=Blocked_Infected_Device: src-mac-address=E2:B5:74:48:FF:AA
add action=drop chain=input comment="Block MAC 86:3a:32:28:b6:d4" log=yes \
log-prefix=Blocked_Infected_Device: src-mac-address=86:3A:32:28:B6:D4
in-interface-list=!LAN log-prefix=Drop_All_Not_Coming_From_Lan:
"SIP Trunk: Block all except SIP Trunk provider" dst-port=35060 log=yes \
log-prefix=Drop_IPs_Other_Than_SIP_Prov: protocol=udp src-address=\
!199.48.65.2
add action=drop chain=forward comment="Block MAC e2:b5:74:48:ff:aa" log=yes \
add action=drop chain=forward comment="Block MAC 86:3a:32:28:b6:d4" log=yes \
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="Drop suspicious SMTP" dst-port=25 \
in-interface=!ether1-WAN1 log=yes log-prefix=suspicious_SMTP_client: \
protocol=tcp src-address=!192.168.1.2
add action=add-src-to-address-list address-list=spammers \
address-list-timeout=3h chain=forward comment=\
"Add Spammers to the list for 3 hours" connection-limit=30,32 dst-port=\
25,587,465 limit=30/1m,0:packet log=yes log-prefix=\
Spammers_AddSpammersToList_ protocol=tcp
add action=drop chain=forward comment="Avoid spammers action" dst-port=\
25,587,465 log=yes log-prefix=DropConnectionsInSpammersList: protocol=tcp \
src-address-list=spammers
add action=drop chain=forward comment="Prevent inter LANs communications" \
in-interface=ether2-LAN4 log=yes log-prefix=\
Drop_Inter_LANs_Communications: out-interface=ether3-LAN3
Drop_Inter_LANs_Communications: out-interface=ether4-LAN2
Drop_Inter_LANs_Communications: out-interface=ether5-LAN1
in-interface=ether3-LAN3 log=yes log-prefix=\
Drop_Inter_LANs_Communications: out-interface=ether2-LAN4
in-interface=ether4-LAN2 log=yes log-prefix=\
in-interface=ether5-LAN1 log=yes log-prefix=\
add action=drop chain=forward comment="defconf: drop invalid 2" \
connection-state=invalid log=yes log-prefix=Drop_Invalid:
connection-state=new in-interface-list=WAN log=yes log-prefix=\
Drop_All_from_WAN_not_DSTNATed:
/ip firewall mangle
add action=mark-connection chain=forward comment="Mark the SiP connection" \
connection-state=new log=yes log-prefix=SIP-Connection: \
new-connection-mark=sip-connection passthrough=yes port=5060 protocol=udp
add action=mark-packet chain=forward comment="Mark the SiP packets" \
connection-mark=sip-connection log-prefix=SIP-Packet: new-packet-mark=SIP \
passthrough=yes
add action=mark-connection chain=forward comment="Mark the RTP connection" \
connection-state=new log=yes log-prefix=RTP-Connection: \
new-connection-mark=rtp-connection passthrough=yes port=16000-16511 \
protocol=udp
add action=mark-packet chain=forward comment="Mark the RTP packets" \
connection-mark=rtp-connection log-prefix=RTP-Packet: new-packet-mark=RTP \
passthrough=yes
add action=dst-nat chain=dstnat comment=RTP dst-port=16000-16511 protocol=udp \
to-addresses=192.168.0.102 to-ports=16000-16511
add action=dst-nat chain=dstnat comment=MGCP dst-port=2727 protocol=udp \
to-addresses=192.168.0.101 to-ports=2727
add action=dst-nat chain=dstnat comment="PTAP (Base and Remote Phones)" \
dst-port=9300 protocol=udp to-addresses=192.168.0.101 to-ports=9300
add action=dst-nat chain=dstnat comment="SIP TRUNK" dst-port=35060 protocol=\
udp src-address=199.48.65.2 to-addresses=192.168.0.101 to-ports=35060
add action=dst-nat chain=dstnat comment="SIP (Mobile Softphone)" dst-port=\
36060 protocol=udp to-addresses=192.168.0.101 to-ports=5060
add action=dst-nat chain=dstnat comment="PBX Remote (https://)" dst-port=5780 \
protocol=tcp to-addresses=192.168.0.101 to-ports=443
/ip firewall service-port
set h323 disabled=yes
set sip disabled=yes
add distance=1 gateway=154.89.111.153
/system clock
set time-zone-autodetect=no time-zone-name=America/Moncton
/system logging
add action=disk topics=critical
add action=disk topics=error
add action=disk topics=info
add action=disk topics=warning
add action=emailBlocked disabled=yes prefix="Blocked Infected Device_" \
topics=info,firewall,critical,error,warning
/system ntp client
set enabled=yes server-dns-names=pool.ntp.org
/tool e-mail
set address=smtp.gmail.com from=thisIs@aTest.com port=587 start-tls=yes \
user=thisIs@aTest.com
/tool mac-server
/tool mac-server mac-winbox
