Hi, newbie with Mikrotik, routeros, looks really goodđ.
Wondering if there is an expert out there who can help me with a configuration for a CRS-4C+8XG.
As clean as possible (performance/security).
Port 1= Wan/ internet switch.
Port 2-8 (1GB), mixed servers and nas. Will reach the internet and also each other.
Port 1T-4T (10GB) only for iSCSI traffic between server and SAN, 100% isolated.
Very important that the performance is maximum on that traffic.
Thanks in advance.
Olle
Or is it better to go for SwithOS?
If properly configured, both OSes should provide equal performance. ROS seems to be much better supported these days (active development) though âŚ
As to ROS configuration: use single bridge and use VLANs (even if they are strictly internal to device) to separate traffic between different port groups. Have a look at this tutorial, it has examples and among others a section âSwitch with a separate routerâ which is similar to what youâre after.
Thanks for your quick reply ![]()
Could you or any helpful person give me some details about configuration of the closed four 10GB port used for iSCSI?
Regards
Olle
I can be helpful, but I donât like spoon-feeding fellow users. So: did you go through tutorial I linked in my previous post? If yes, what exactly seems to be a problem?
My question was because I donât want to experiment with my current SAN- connection.
I make a vlan and make the ports untagged , yes?
And I make no trunkport (connection)?
Olle
Correct. You also donât add bridge port to list of VLAN members.
