I am shortly going to receive a new internet service (known as ‘ethernet over copper’) - it is delivered as a L2 VLAN from the provided NTU. Up to 6 IP addresses can be used.
I really only have experience with PPPoE connections and am having trouble thinking how this connection type is implemented (both generally and in RouterOS). Would anyone be able to post some config export rules for me to see?
Its just an Ethernet hand-off. You will either be using a DHCP client or you will be assigned a Static IP and Gateway. All in all, it will almost identical to other setups.
Ah, fantastic. So I do not need to make any VLAN arrangements specifically for the connection, then.
I would have thought that if I were being given an IP and gateway, that would be referred to as ‘layer 3’ not ‘layer 2’, yet the connection type is consistently referred to, by the ISP, as ‘layer 2’. I guess that threw me.
They supply a NTU, which I suppose is technically a bridge also.
I will ask them, but hoped to be able to find out for myself first. They are not usually very helpful with this kind of enquiry, unless it is of a very specific nature (‘do I need to enable this particular function’).
