Config gone, not in Winbox
I have a RB411 that we did a /sys reset on and now it will not show up in Winbox at all. How do you reset the RB to default using something on the board, i.e. hardware reset?
you need a serial cable. Use netinstall to reinstall the software.
try with ssh, telnet and then with serial cable…
