config on a 450G
Hi
Up to now I have been using two dsl mlpp lines on my 450G (ether 1 and 2) It gives me 7 down 1 up
The 450 is the dhcp server
I just ordered a cable line its 10 down 1 up.
Is load balancing my best choice in this case. All 70 subs are served out of ether 5 (it goes to my backhaul)
thanks
PCC is probably your best bet.
they just installed it with a modem and a cisco 851 router.
will probably need someone like Butch or Dennis Burgess to do it
I tried going from router to Mikrotik just to try switching from dsl to cable
but could not get that working even though I got instructions on dsl reports :frowning:
