Config Thoughts?
Hello everybody,
I am using an RB5009 and I’ve decided to redo some things on my config, and as requested I will now post my whole config with some censoring.
Hopefully this helps, any suggestions are welcome.
add mtu=1500 name=trunk vlan-filtering=yes
# poe-out status: no_valid_psu
set [ find default-name=ether8 ] name=ether8-gateway
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether8-gateway max-mru=1480 \
    max-mtu=1480 name=WAN1 user=CENSORED
/interface vlan
add interface=trunk name=v88-Primary vlan-id=88
add name=WAN-Interfaces
add name=mac-winbox
add name=v88-Primary ranges=192.168.1.100-192.168.1.250
add address-pool=v88-Primary authoritative=after-2sec-delay interface=\
    v88-Primary lease-time=3d name=v88-Primary
/ppp profile
set *0 on-up="/system script run ppp-up"
add bridge=trunk frame-types=admit-only-untagged-and-priority-tagged \
    interface=ether2 pvid=88
    interface=ether3 pvid=88
    interface=ether4 pvid=88
    interface=ether5 pvid=88
    interface=ether6 pvid=88
    interface=ether7 pvid=88
    interface=ether1 pvid=88
set enabled=yes generic-timeout=20m tcp-time-wait-timeout=20s \
    udp-stream-timeout=5m udp-timeout=20s
set discover-interface-list=mac-winbox
/ip settings
set allow-fast-path=no
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=trunk tagged=trunk vlan-ids=88
add interface=v88-Primary list=mac-winbox
add interface=WAN1 list=WAN-Interfaces
add interface=ether8-gateway list=WAN-Interfaces
add address=192.168.1.1/24 interface=v88-Primary network=192.168.1.0
/ip cloud
set ddns-enabled=yes
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1 \
    netmask=24
set allow-remote-requests=yes use-doh-server=https://1.1.1.1/dns-query \
    verify-doh-cert=yes
/ip firewall address-list
add address=192.168.1.0/24 list=ACL
add address=CENSORED list=ACL
add address=CENSORED list="VoIP QoS Servers"
add action=jump chain=forward comment=\
    "Jump packets going to v88-Primary interface to v88-Primary chain." \
    jump-target=v88-Primary out-interface=v88-Primary
    "Accept established, related and untracked packets." connection-state=\
    established,related,untracked
add action=drop chain=input comment="Drop invalid packets." connection-state=\
    invalid
    "Accept ping packets from ACL address list." protocol=icmp \
    src-address-list=ACL
    "Accept Webfig/Winbox access from ACL address list." dst-port=80,8291 \
    in-interface-list=WAN-Interfaces protocol=tcp src-address-list=ACL
add action=accept chain=input comment="Accept internal DNS requests." \
    dst-port=53 in-interface-list=!WAN-Interfaces protocol=udp
    dst-port=53 in-interface-list=!WAN-Interfaces protocol=tcp
    "Accept connections from v88-Primary VLAN." in-interface=v88-Primary
add action=drop chain=input comment="Drop remaining packets."
add action=accept chain=v88-Primary comment=\
add action=drop chain=v88-Primary comment="Drop invalid packets." \
    connection-state=invalid
add action=accept chain=v88-Primary comment="Accept port forwarding." \
    connection-nat-state=dstnat connection-state=new
add action=drop chain=v88-Primary comment="Drop remaining packets."
add action=masquerade chain=srcnat out-interface=WAN1
/ip firewall service-port
set h323 disabled=yes
set sip disabled=yes
/ip service
set telnet disabled=yes
set ftp disabled=yes
/system clock
set time-zone-autodetect=no time-zone-name=CENSORED
/system identity
set name="CENSORED"
/system logging
add action=disk topics=critical
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
/system scheduler
add interval=1h name=CENSORED-router-update-device on-event=\
    CENSORED-router-update-device policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=2024-06-07 start-time=08:04:02
add interval=1h name=CENSORED-update-interfaces on-event=CENSORED-update-interfaces \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
/system script
add dont-require-permissions=no name=ppp-up owner=CENSORED policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="/\
    ip firewall connection remove [ find ]\r\
    \n\r\
    \n/system script run CENSORED-router-update-device\r\
    \n\r\
    \n"
add dont-require-permissions=no name=CENSORED-router-update-device owner=CENSORED \
    source=":local clouddns [/ip cloud get dns-name] \
    \n:local serial [/system routerboard get serial-number]\
    \n\
    \n:local model [/system resource get board-name]\
    \n:local osversion [/system resource get version]\
    \n\
    \n:local sshport ([/ip service get ssh port])\
    \n:local winboxport ([/ip service get winbox port])\
    \n:local httpport ([/ip service get www port])\
    \n\
    \n\
    \n:local poststring \"hostname=\$clouddns&serial=\$serial&ssh_port=\$sshpo\
    rt&winbox_port=\$winboxport&http_port=\$httpport&model=\$model&os_version=\
    \$osversion\"\
    \n:log info \$poststring\
    \n/tool fetch CENSORED
    a3c-58ef-919a-213d3b33e40f http-method=post http-data=\$poststring"
add dont-require-permissions=no name=CENSORED-update-interfaces owner=CENSORED \
    source=":local clouddns [/ip cloud get dns-name]\r\
    \n:local serial [/system routerboard get serial-number]\r\
    \n\r\
    \n:local wanname \"WAN1\"\r\
    \n:local wanip \"\"\r\
    \n:local wanmac \"\"\r\
    \n:local webproxystatus [/ip proxy get enabled]\r\
    \n:local failoverwanname \"ether2-4g\"\r\
    \n:local failoverwanip \"\"\r\
    \n:local failoverwanmac \"\"\r\
    \n:local arp \"\"\r\
    \n:local addresses ([/ip address find where interface=\$wanname ] )\r\
    \nforeach line in=\$addresses do={\r\
    \n :set wanip [/ip address get \$line address];\r\
    \n :set wanmac [/interface get \$wanname mac-address];\r\
    \n}\r\
    \n:local addresses ([/ip address find where interface=\$failoverwanname ] \
    )\r\
    \n :set failoverwanip [/ip address get \$line address];\r\
    \n :set failoverwanmac [/interface get \$failoverwanname mac-address];\r\
    \n}\r\
    \n:local arps ([/ip arp find ] )\r\
    \nforeach line in=\$arps do={\r\
    \n :set arp (\$arp . [/ip arp get \$line address ] . \" \" . [/ip arp get \
    \$line mac-address ] . \" \" . [/ip arp get \$line interface ] . \",\")\r\
    \n \r\
    \n}\r\
    \n:local poststring \"hostname=\$clouddns&serial=\$serial&webproxy_enabled\
    =\$webproxystatus&primary_wan_name=\$wanname&primary_wan_int_mac=\$wanmac&\
    primary_wan_ip=\$wanip&failover_wan_ip=\$failoverwanip&failover_wan_mac=\$\
    failoverwanmac&failover_wan_name=\$failoverwanname&arp_table=\$arp\"\r\
    \n:put \$poststring\r\
/tool mac-server
set allowed-interface-list=mac-winbox
/tool mac-server mac-winbox
/export file=anynameyouwish ( minus router serial number, any public WANIP information, keys etc. )
Hi anav, thanks for your reply, I’ve updated the OP with the details you requested, thank you.
If you can put code tags around the config, it is more readable. Use the </> button to establish in the editor.
Learning all of the things, haha. Done, thank you!
(1) If the name of your vlan is name=v88-Primary
Dont use the same name for everything else, WAY WAY too confusing.
Right now your IP pool, dhc-server etc have the same name…
