hola buen dia comunidad, tengo un equipo Mantbox ax 15 s, normalmente he usado el 19s, y me han enviado el modelo ax 15s, y quisiera saber alguna info en cuanto a su coniguracion en modo AP, quiero conectar las lhg5 a la mantbox, si me podrian dar alguna info, gracias
They're two completely different things; no nv2, no MikroTik driver, no this and no that... if you're using them as a WISP, you're screwed...
And please, don't be rude and write in English in English forums.
Please use English (if you are not familiar with it, use translator) as it's a English based forum.
Excuse me, but regarding the language issue, what equipment do you recommend for multipoint connections since I have my Mantbox AX 15s? What client devices are recommended? Because the LHG5s aren't compatible, that's what I understand.
