Good morning,
I bought my first Mikrotik device last year for my new home network and I managed to configure the network the way I wanted to by spending a lot of time on the official wiki and on Youtube. One of the first things I did, it was to configure the firewall using the commands that the official wiki suggested for better security. So as you have already understood I want to check if there is something wrong with that configuration cause I’m still learning and I’m not an expert.
The second thing that I want to ask you is about creating a new VLAN on a specific port for the new surveillance system that I’m gonna install. For example I want to put it on ethernet port 4 and access it only with the VPN. I have already managed to configure the Wireguard VPN on my router so I can access it remotely from my iPhone and my MacBook but i have some difficulties in isolating a specific port (it should not talk with the other VLANs) and accessing the device connected only behind VPN.
add admin-mac= auto-mac=no comment=defconf name=bridge
/interface wireguard
add listen-port=13231 mtu=1420 name=Wireguard_Server
/interface vlan
add interface=ether1 name=VLAN_DIMENSIONE vlan-id=835
add interface=ether5 name=VLAN_Home vlan-id=30
add interface=ether5 name=VLAN_IoT vlan-id=10
add interface=ether5 name=VLAN_WIFI_GUEST vlan-id=20
/interface pppoe-client
add add-default-route=yes dial-on-demand=yes disabled=no interface=\
VLAN_DIMENSIONE keepalive-timeout=disabled name=pppoe_dimensione user=\
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp_pool1 ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool2 ranges=192.168.20.2-192.168.20.254
add name=dhcp_pool3 ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool4 ranges=192.168.20.2-192.168.20.254
add name=dhcp_pool5 ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool6 ranges=10.0.20.2-10.0.20.254
add name=dhcp_pool7 ranges=10.0.10.10-10.0.10.100
add name=dhcp_pool8 ranges=10.0.30.2-10.0.30.254
add address-pool=default-dhcp interface=bridge name=defconf
add address-pool=dhcp_pool6 interface=VLAN_WIFI_GUEST name=DHCP_WIFI
add address-pool=dhcp_pool7 interface=VLAN_IoT name=DHCP_IoT
add address-pool=dhcp_pool8 interface=VLAN_Home name=DHCP_Home
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add comment=defconf interface=VLAN_DIMENSIONE list=WAN
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=172.16.10.2/32 interface=Wireguard_Server public-key=\
add allowed-address=172.16.10.3/32 interface=Wireguard_Server public-key=\
192.168.88.0
add address=10.0.10.1/24 interface=VLAN_IoT network=10.0.10.0
add address=10.0.20.1/24 interface=VLAN_WIFI_GUEST network=10.0.20.0
add address=10.0.30.1/24 interface=VLAN_Home network=10.0.30.0
add address=172.16.10.1/24 interface=Wireguard_Server network=172.16.10.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
/ip cloud advanced
set use-local-address=yes
/ip dhcp-client
add comment=defconf interface=VLAN_DIMENSIONE use-peer-dns=no
add address=10.0.10.0/24 gateway=10.0.10.1
add address=10.0.20.0/24 gateway=10.0.20.1
add address=10.0.30.0/24 gateway=10.0.30.1
set allow-remote-requests=yes use-doh-server=https://dns.nextdns.io/***** \
verify-doh-cert=yes
/ip dns static
add address=45.90.28.0 name=dns.nextdns.io
add address=45.90.30.0 name=dns.nextdns.io
add address=2a07:a8c0:: name=dns.nextdns.io type=AAAA
add address=2a07:a8c1:: name=dns.nextdns.io type=AAAA
/ip firewall address-list
add address=192.168.88.2-192.168.88.254 list=allowed_to_router
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=\
not_in_internet
add action=accept chain=input comment="allow WireGuard" dst-port=13231 \
protocol=udp
add action=accept chain=input comment="allow WireGuard traffic" src-address=\
172.16.10.0/24
established,related,untracked
invalid
add action=accept chain=input dst-port=53 in-interface=all-vlan protocol=tcp
add action=accept chain=input dst-port=53 in-interface=all-vlan protocol=udp
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=accept chain=input comment="default configuration" \
add action=accept chain=input src-address-list=allowed_to_router
add action=drop chain=input
add action=fasttrack-connection chain=forward comment=FastTrack \
add action=accept chain=forward comment="Established, Related" \
add action=drop chain=forward comment="Drop invalid" connection-state=invalid \
log=yes log-prefix=invalid
"Drop tries to reach not public addresses from LAN" dst-address-list=\
not_in_internet in-interface=bridge log=yes log-prefix=!public_from_LAN \
out-interface=!bridge
"Drop incoming packets that are not NAT`ted" connection-nat-state=!dstnat \
connection-state=new in-interface=ether1 log=yes log-prefix=!NAT
add action=jump chain=forward comment="jump to ICMP filters" jump-target=icmp \
protocol=icmp
"Drop incoming from internet which is not public IP" in-interface=ether1 \
log=yes log-prefix=!public src-address-list=not_in_internet
"Drop packets from LAN that do not have LAN IP" in-interface=bridge log=\
yes log-prefix=LAN_!LAN src-address=!192.168.88.0/24
add action=accept chain=icmp comment="echo reply" icmp-options=0:0 protocol=\
icmp
add action=accept chain=icmp comment="net unreachable" icmp-options=3:0 \
protocol=icmp
add action=accept chain=icmp comment="host unreachable" icmp-options=3:1 \
protocol=icmp
add action=accept chain=icmp comment=\
"host unreachable fragmentation required" icmp-options=3:4 protocol=icmp
add action=accept chain=icmp comment="allow echo request" icmp-options=8:0 \
protocol=icmp
add action=accept chain=icmp comment="allow time exceed" icmp-options=11:0 \
protocol=icmp
add action=accept chain=icmp comment="allow parameter bad" icmp-options=12:0 \
protocol=icmp
add action=drop chain=icmp comment="deny all other types"
add action=fasttrack-connection chain=forward connection-state=\
established,related hw-offload=yes
add action=accept chain=forward connection-state=established,related
add action=drop chain=input comment="Drop Port 53 UDP" connection-state="" \
dst-port=53 in-interface=pppoe_dimensione protocol=udp
add action=drop chain=input comment="Drop Port 53 TCP" connection-state="" \
dst-port=53 in-interface=pppoe_dimensione protocol=tcp
add action=masquerade chain=srcnat out-interface=pppoe_dimensione \
src-address=10.0.20.0/24
src-address=10.0.10.0/24
src-address=192.168.88.0/24
src-address=10.0.30.0/24
add action=redirect chain=dstnat dst-port=53 protocol=tcp
add action=redirect chain=dstnat dst-port=53 protocol=udp
src-address=172.16.10.0/24
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip service
set telnet disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 address
add address= ******** from-pool=IPv6_Dimensione interface=bridge
/ipv6 dhcp-client
add interface=pppoe_dimensione pool-name=IPv6_Dimensione request=prefix \
use-peer-dns=no
/ipv6 firewall address-list
add address=fd12:672e:6f65:8899::/64 list=allowed
add address=fe80::/16 list=allowed
add address=ff02::/16 comment=multicast list=allowed
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
add action=accept chain=input comment="allow established and related" \
add action=accept chain=input comment="accept ICMPv6" protocol=icmpv6
"accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp \
src-address=fe80::/16
add action=accept chain=input comment="allow allowed addresses" \
add action=accept chain=forward comment=established,related connection-state=\
established,related
add action=drop chain=forward comment=invalid connection-state=invalid log=\
yes log-prefix=ipv6,invalid
add action=drop chain=forward disabled=yes log-prefix=IPV6
/ipv6 nd
set [ find default=yes ] interface=bridge
/snmp
set contact= location=Network trap-generators=\
start-trap trap-interfaces=all trap-version=3
/system clock
set time-zone-name=
/tool mac-server
/tool mac-server mac-winbox
