Configuration Errors
Besides commands like /interface, is there any other configuration to configure? I’m getting an error with my wireless configuration settings.
It rains here …
That’s about the same amount of info as what you gave.
What device ?
What error ?
How do you want your router to work ? What are the requirements ?
How does your config look like ?
From terminal: /export filename=anynameyouwish
Move file to your PC, open in editor, remove sensitive info like serial number, public WAN IP, passwords, …
Then post edited content in between [__code] quotes for easier readability.
and: where did you get the configuration stance that’s failing (from ChatGPT)?
Its so gratifying to see my former students, all graduated and shit, showing their true sarcastic selves…
What can I say? You were (and stil are) a tough teacher.
