I made configuration examples for the beginner and set these on my website.
http://www.wirelessinfo.be/index.php/mikrotik/pages/confige
4 configurations examples
The aim of this page is to present “ready to go” and easy adjustable configurations to the inexperienced Mikrotik Routerboard user. You should reset the Routerboard without default configuration. After the reset, open Winbox and paste the code in a “new terminal” window. Restart, and the configuration will work.
Configuration1
extra SSID guest in other network.
Configuration2
In this example, the wireless interface of the Routerboard connects to an access point or hotspot. Using the Ethernet interfaces 1 to 5 you can connect your computer.
Configuration3
A special solution for people living on boats that are docked in a harbor.
Configuration4
With RB2011 UAS-RM and Groove A52HpN
The Groove will broadcast 2 SSID s: “guest” and “private”. These are both in separate networks, to prevent the guests from accessing the private network. A firewall rule on the Routerboard RB2011 UAS-RM will prevent this.
Configuration5
With RB951G-2HND and RB2011 UAS-RM
Double WAN failover with load balancing
I hope this are usefull
