Hello,I bought new rb751u-2HnD,but can’t configuration him normaly with WinBox.
i have connection from provaider and i need connect with router 2 PC.
i think of 2 day but now i am sick of swiching between routers…
[admin@MikroTik] > /export
# jan/02/1970 00:27:21 by RouterOS 5.6
# software id = J6LT-WRXF
set 0 arp=enabled auto-negotiation=yes comment=Provaiders disabled=no \
full-duplex=yes l2mtu=1600 mac-address=00:1C:C0:08:2A:28 mtu=1500 name=\
ether1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
Lan disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:FB:54:15 \
master-port=none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\
no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:FB:54:16 master-port=\
none mtu=1500 name=ether3 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\
no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:FB:54:17 master-port=\
none mtu=1500 name=ether4 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\
no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:FB:54:18 master-port=\
none mtu=1500 name=ether5 speed=100Mbps
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1
set default authentication-types="" eap-methods=passthrough group-ciphers="" \
group-key-update=5m interim-update=0s management-protection=disabled \
management-protection-key="" mode=none name=default radius-eap-accounting=\
no radius-mac-accounting=no radius-mac-authentication=no \
radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX \
radius-mac-mode=as-username static-algo-0=none static-algo-1=none \
static-algo-2=none static-algo-3=none static-key-0="" static-key-1="" \
static-key-2="" static-key-3="" static-sta-private-algo=none \
static-sta-private-key="" static-transmit-key=key-0 supplicant-identity=\
MikroTik tls-certificate=none tls-mode=no-certificates unicast-ciphers="" \
wpa-pre-shared-key="" wpa2-pre-shared-key=""
/interface wireless
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 \
antenna-mode=ant-a area="" arp=enabled band=2ghz-b basic-rates-a/g=6Mbps \
basic-rates-b=1Mbps bridge-mode=enabled channel-width=20mhz compression=no \
country=no_country_set default-ap-tx-limit=0 default-authentication=yes \
default-client-tx-limit=0 default-forwarding=yes dfs-mode=none \
disable-running-check=no disabled=yes disconnect-timeout=3s distance=\
dynamic frame-lifetime=0 frequency=2412 frequency-mode=manual-txpower \
frequency-offset=0 hide-ssid=no ht-ampdu-priorities=0 ht-amsdu-limit=8192 \
ht-amsdu-threshold=8192 ht-basic-mcs=\
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-guard-interval=any \
ht-rxchains=0 ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mc\
s-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-\
18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" ht-txchains=0 \
hw-fragmentation-threshold=disabled hw-protection-mode=none \
hw-protection-threshold=0 hw-retries=7 l2mtu=2290 mac-address=\
00:0C:42:FB:54:19 max-station-count=2007 mode=station mtu=1500 name=wlan1 \
noise-floor-threshold=default nv2-cell-radius=30 nv2-noise-floor-offset=\
default nv2-preshared-key="" nv2-qos=default nv2-queue-count=2 \
nv2-security=disabled on-fail-retry-time=100ms periodic-calibration=default \
periodic-calibration-interval=60 preamble-mode=both proprietary-extensions=\
post-2.9.25 radio-name=000C42FB5419 rate-selection=legacy rate-set=default \
scan-list=default security-profile=default ssid=MikroTik \
station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=\
1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-power-mode=default \
update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=\
none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled \
wireless-protocol=unspecified wmm-support=disabled
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp\
s:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,H\
T20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:\
17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17"
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
3200 framer-policy=none
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot \
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap \
name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no \
use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=1 \
status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m \
name=default pfs-group=modp1024
add name=dhcp_pool1 ranges=84.237.222.2-84.237.222.254
add name=dhcp_pool2 ranges=0.0.0.2-255.255.255.254
add name=dhcp_pool3 ranges=0.0.0.2-255.255.255.254
add name=dhcp_pool4 ranges=84.237.222.2-84.237.222.254
add address-pool=dhcp_pool3 authoritative=after-2sec-delay bootp-support=static \
disabled=no interface=ether2 lease-time=3d name=dhcp1 relay=0.0.0.1
add address-pool=dhcp_pool4 authoritative=after-2sec-delay bootp-support=static \
disabled=no interface=ether1 lease-time=3d name=dhcp2 relay=0.0.0.1
/ppp profile
set default change-tcp-mss=yes name=default only-one=default use-compression=\
default use-encryption=default use-mpls=default use-vj-compression=default
set default-encryption change-tcp-mss=yes name=default-encryption only-one=\
default use-compression=default use-encryption=yes use-mpls=default \
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=\
5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 \
red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set default-small kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no \
ignore-as-path-len=no name=default out-filter="" redistribute-connected=no \
redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set default disabled=no distribute-default=never in-filter=ospf-in metric-bgp=\
auto metric-connected=20 metric-default=1 metric-other-ospf=auto \
metric-rip=20 metric-static=20 name=default out-filter=ospf-out \
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set backbone area-id=0.0.0.0 disabled=no instance=default name=backbone type=\
default
/snmp
set contact="" enabled=no engine-id="" location="" trap-target=0.0.0.0 \
trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-password="" \
authentication-protocol=MD5 encryption-password="" encryption-protocol=DES \
name=public read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote-port=514 src-address=0.0.0.0 \
syslog-facility=daemon syslog-severity=auto target=remote
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet \
boot-protocol=bootp enable-jumper-reset=yes enter-setup-on=any-key \
force-backup-booter=no silent-boot=no
/user group
add name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,web,snif\
f,sensitive,api,!ftp,!write,!policy" skin=default
add name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,password,w\
eb,sniff,sensitive,api,!ftp,!policy" skin=default
add name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,\
password,web,sniff,sensitive,api" skin=default
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
set ether2 vlan-header=leave-as-is vlan-mode=fallback
set ether3 vlan-header=leave-as-is vlan-mode=fallback
set ether4 vlan-header=leave-as-is vlan-mode=fallback
set ether5 vlan-header=leave-as-is vlan-mode=fallback
set switch1_cpu vlan-header=leave-as-is vlan-mode=fallback
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption \
enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
default enabled=no keepalive-timeout=60 mac-address=FE:D4:8D:48:6B:D9 \
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=\
no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=\
disabled port=443 verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no \
streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=84.237.222.104/24 disabled=no interface=ether1 network=84.237.222.0
/ip dhcp-server config
set store-leases-disk=5m
add address=0.0.0.0/0 gateway=0.0.0.1
add address=84.237.222.0/24 gateway=84.237.222.1
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB \
max-udp-packet-size=512 servers=81.198.60.10,195.13.0.160
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=\
10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s \
tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s \
udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=srcnat disabled=no out-interface=!ether1
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set ether1 disabled=no
set ether2 disabled=no
set ether3 disabled=no
set ether4 disabled=no
set ether5 disabled=no
set wlan1 disabled=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
cache-on-disk=no enabled=no max-cache-size=none max-client-connections=600 \
max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \
parent-proxy-port=0 port=8080 serialize-connections=no src-address=0.0.0.0
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=84.237.222.1 scope=30 \
target-scope=10
/ip service
set telnet disabled=no port=23
set ftp disabled=no port=21
set www disabled=no port=80
set ssh disabled=no port=22
set www-ssl certificate=none disabled=yes port=443
set api disabled=yes port=8728
set winbox disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip ssh
set forwarding-enabled=no
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no inactive-flow-timeout=\
15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
add disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
use-explicit-null=no
/port firmware
set directory=firmware
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1 queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
set ether4 queue=ethernet-default
set ether5 queue=ethernet-default
set wlan1 queue=wireless-default
/radius incoming
set accept=no port=3799
/routing bfd interface
set all disabled=no interface=all interval=0.2sec min-rx=0.2sec multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
redistribute-connected=no redistribute-ospf=no redistribute-static=no \
routing-table=main timeout-timer=3m update-timer=30s
/store
add disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
"jan/01/1970 00:00:00" time-zone=+00:00
/system health
set
/system identity
set name=MikroTik
/system leds
add disabled=no interface=wlan1 leds=wlan-led type=wireless-status
/system logging
add action=memory disabled=no prefix="" topics=info
add action=memory disabled=no prefix="" topics=error
add action=memory disabled=no prefix="" topics=warning
add action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no mode=broadcast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
set (unknown) disabled=no interface=all
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=10 file-name="" filter-address1=0.0.0.0/0:0-65535 \
filter-address2=0.0.0.0/0:0-65535 filter-protocol=all-frames filter-stream=\
yes interface=all memory-limit=10 memory-scroll=yes only-headers=no \
streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
[admin@MikroTik] >
