As in topic, I’ve moved configuration from routerboard 750 to hex and it doesnt work. Inside web is working, there is connection between devices but cant go to internet, what should I do, reset macs or what? I tried with backuping binary file and from export/import config to terminal too.
Thanks for your help,
Best regards
Hey
Backup can only be used on same hardware. When migrating to different one, you should export configuration (/export compact file=) and import that on target.
When importing, you’ll need to adjust to new hardware configuration.
Hey,
your tip worked well, my internet is working, both lan and wifi but still cannot connect to vpn (l2tp), also I cant even enable openvpn server(Wrong certificate error),link to picture below.
Asking for more help what should I configurate.
https://imgur.com/6i3YieF
Best regards
certificate doesn’t get exported with /export. You’ll need to do it manually: export (or grab backup) and import on new router.
I made a new certificate, but the is problem with l2tp vpn connection, l2tp/ipsec tunnel issue, how may I solve that?
Start a new thread and provide some info: what problem you see, any logs and the current configuration
