Configuration Management Server
I am recently searching for a kind of configuration management server. I know it’s possible to use CAPsMAN to manage different MikroTik devices. But this is a controller based solution. If the controller fails, your whole network will crush.
As far as I know the Dude is just a monitoring server, correct me if I am wrong.
Can anyone recommend an alternativ to manage a lot of MikroTik devices, for example a server that just pushes the configuration file to your different MikroTik devices.
Regards :smiley:
Hi fabiosanchez27,
actually configuration provisioning as to be deployed using script (as you noticed, CAPSMAN do it for wireless interface but it cannot support controller-less mode; if you play and spend sometimes with scripting, you can find a solution for them).
If you set a device on dude as RouterOS, you are able to view and edit many settings using Dude, please check here:
http://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/Device_settings
