configuration multiple public IP address
i have 5 ip public from isp
and i put these ip on DVRs “Digital Video Recorder” and configuration beside network using at Adsl Router
“Secondary IP Address” and “Multi-NAT function ( IP address mapping for multiple IP servers)”
it working outside and inside network
now i using routerboard rb951ui-2hnd how can configuration DVR working with my existing network
i upload diagram
Is there a reason you aren’t putting your modem into bridge mode?
because my isp work only PPPoE
Can put the modem in bridge and use the Mikrotik to do the PPPoE connection.
Sent from my SM-G900H using Tapatalk
ok i will do this
