Configuration replication
I have two CCR1009-8G-1s-1s+ configured with VRRP configured for auto fail over - all is working well.
I am looking for a why to have the configuration from the primary device automatically replicated to the secondary device.
The desired configuration is to reduce the IT overhead and eliminate human error in entering the same rules twice.
Ideally this would be scripted - logic being;
Export config from ROS1
Change IP address of LAN interface
Change VRRP priority
Disable all WAN interfaces
Reset ROS2
Clear config
Import config to ROS2.
I am trying to script it myself but having some issues.
I have an open thread in the scripting forum. http://forum.mikrotik.com/t/unable-to-get-property-name/92033/1
Any advice on how to achieve the above would be great.
Thanks.
This is a very old thread, but after 10 years, I can't believe this has not been done yet.
