Configuration Wifi - Hap Ac Lite
Hello everyone, this is my first Mikrotik router and I must be lost getting the 2.4Ghz and 5Ghz wifi to work.
I have a Hap AC LITE (RouterOS 7.5) connected to my internet provider router, there are 2 computers connected in RJ45, All the parameters are by default and it works as it should, I never added anything that is.
I wanted to use my Mac M1 laptop in Wifi but I can’t manage to configure the wifi of the Hap AC LITE router.
In interface there is Wlan1 and Walan2 but impossible to activate ( managed by CAPsMAN ) Couldn’t change Interface - interface managed by CAPsMAN (6)
In the Quick Set / Home Hap Dual / Local network parameters, I have to fill in request an ip address and whatever I enter when I apply the changes, I cannot access the router and the wifi connection does not arrive at retrieve an ip address and there is no internet connection.
I have to reset everything every time because it is impossible to reconnect to the router.
Can you help me please.
Never use QuickSet after first configuration (or better, at all)
Go to WebFig / CAPsMAN section and manage the device…
thank you for your reply
In the CaPsMan configurations there is nothing, what should I do to make the wifi work?
Go on (the same screen) wireless menu on the left, click “CAP” button and disable CAP.
Manager button and disable.
Thank you all for your help, working fine. ( Resolved )
Merci à tous ^^
