Configuration
Iv been playing with the Microtik RouterBoard 750 for some time now and cant seem to get it working to access internet.
First a bit on my network. I have a satallite modem that connects in Port 1, port 2 is then for the local network and should have addresses in the 10.0.0.* range, port 3 is the public network and should have in the range 192.168.1.*.
Now i have gone through everything and been able to set up dhcp so when i plug in my laptop into port 2 i get an address, but i get no internet. Little help please.
so port 1 has the internet settings correctly, then port 2 has 10.0.0.1. It works fine and i get internet and all. Port 3 now is the problem, its set to 192.168.1.1 but i get ip addresses in the range 10.0.0.*. Why is that?
Do one of these and post output.
/interface ethernet print
you have either a bridge or a switch configured, you must disable that. post your ethernet settings, as the above poster asked
[admin@MikroTik] > /interface ethernet print
Flags: X - disabled, R - running, S - slave
 #    NAME      MTU   MAC-ADDRESS       ARP        MASTER-PORT      SWITCH
 0    modem     1500  00:0C:42:5A:7D:7A enabled
 1 R  local     1500  00:0C:42:5A:7D:7B enabled    none             switch1
 2 RS public    1500  00:0C:42:5A:7D:7C enabled    local            switch1
 3  S ether4... 1500  00:0C:42:5A:7D:7D enabled    local            switch1
 4  S ether5... 1500  00:0C:42:5A:7D:7E enabled    local            switch1
It works but i dont find it reliable, goes on and off sometimes. Also some people connecting on my system i cannot ping while others i can. Yet the ones i cant ping have a connection
any ideas?
