Hello!
I would like to create a configuration with the following properties:
- LAN ports: Ethernet ports and Wifi 5GHz
- LTE is the default gateway
- 2.4 GHz Wifi is the gateway if connected
- The LAN network is NAT-ed
So my question is how can I set the 2.4GHz wifi from the terminal to connect to an AP (under SSID with password) and operate as a gateway?
Mikrotik router: https://mikrotik.com/product/wap_ac_lte_kit
