I would like to extend my house wifi router to get wifi coverage at the far end of the house and out to the bunkhouse, about an extra 20m.
I have purchased two small MikroTik really cool little wifi routers, hAP minis. I would l like to configure them as slave APs to my main AP.
Both would have the same SSID and password as the main AP.
Both would be on the same subnet as the main AP.
They would be connected via an ethernet cable, first to the one at the end of the house and from that one out to the bunkhouse.
I’m sure that there is an easy way to configure this but I just can’t find it. Most of the RouterOS expressions are meaningless to me.
Running Capsman is not an option for me. The bad signal on a device is not an issue for me.
Using Webfig I therefore change the mode from “Router” to “Bridge”.
The main router has IP 192.168.0.1 so I have set static IPs on the two devices of 192.168.0.2 and 192.168.0.3.
I’m assuming that this will turn off DHCP and NAT but is there anything else to look for?, maybe firewall or something?
