I’m new to mikrotik so pardon my silly question but I just bought my first RB1100 router and I want to connect my two cisco wap 371ak9. I did all the initial configuration on both devices but for some reason the still can’t get the Cisco aps to get internet access. I think when I connect wirelease to the aps I am not getting any ip address from the mikrotik router. Can someone please advise what should I do.
The mikrotik is not with me now but her is the config:
Port 1 is the wan port.
Port 2 till 13 bridged together and a dhcp is enabled on them 192.168.1.0/24
And the aps have a static IPs that are 192.168.1.245 and 192.168.1.246
feb/25/2017 18:51:10 system,error,critical login failure for user root from 78.21
2.173.62 via ssh
2.173.62 via ssh
feb/25/2017 19:18:14 system,error,critical login failure for user root from 186.1
78.28.143 via ssh
78.28.143 via ssh
feb/25/2017 19:18:15 system,error,critical login failure for user root from 186.1
78.28.143 via ssh
78.28.143 via ssh
78.28.143 via ssh
78.28.143 via ssh
looking at your config there is one big issue standing out. you have mutiple dhcp pools and dhcp servers all operating in the same bride. I would suggest removing them all and creating 1 that covers what you are wanting to do. Second thing. Once you have completed the changes plug a computer into the port you Waps connect to and ensure you get a dhcp address. that way you know your router config is working.
