"Configure multiple public ip addresses" Is the guide still valid after V6.41?
Hi, everyone,
I found this guide:
https://www.youtube.com/watch?v=BkQ-jNNky_k
…and wanted to ask you whether it still works in this form with RouterOS V6.41 → V6.48?
The instructions deal with multiple IP addresses assigned by the ISP. More precisely, how can I put three IP addresses on three LAN ports (e.g. Ether 2 - 4)?
Thank you very much, I look forward to every answer!
HPLearner
The same way as you would do with any other address space…
  • Assign the address to your Interface with the correct CIDR
  • Configure your Route rules
  • Configure your NAT rules
Thanks for your answer!
So can I follow the instructions?
I got version V6.47.
Greetings
Draw a diagram with your network topology… Specify your requirements and you can /export hide-sensitive=yes your configuration when you have some working config…
I don’t know what the video describes and if the requirements for your network are the same… so i can’t say if you should follow it or not…
As said in my previous post, there is nothing special on assigning a Public IP address to your interfaces …
Thanks for your answer. I will try it…
Best Greetings
