Configure RB750 for IPTV
Hi.
I’ve been struggling to get my RB750 to work for IPTV.
My ISP uses Vlan10 for internet/PPPOE and i’ve configured it successfully.
My problem is that Multicast comes from VLAN12 and i dont seem to get an IP address in the DHCP client i have for that vlan.
Is there any configuration i’m missing ?
This is my current configuration
[admin@MikroTik] > interface vlan print
Flags: X - disabled, R - running, S - slave
 #    NAME                    MTU ARP        VLAN-ID INTERFACE
 0 R  vlan.10                1500 enabled         10 ether1-gateway
 1 R  vlan.12                1500 enabled         12 ether1-gateway
[admin@MikroTik] > ip dhcp-client print
 #   INTERFACE                         USE ADD STATUS        ADDRESS
 0   vlan.12                           yes yes searching...
[admin@MikroTik] > ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   192.168.2.254/24   192.168.2.0     ether2-master-local
 1 D 188.83.122.18/32   194.65.169.237  IPTV-Internet
Thanks in advance,
Please post /ip address print /ip firewall export /interfaces print detail /ip route print detail
Hi ,
Here it is.
[admin@MikroTik] > /ip address print
 1 D 188.83.116.35/32   194.65.169.237  IPTV-Internet
[admin@MikroTik] > ip firewall export
# mar/08/2012 14:39:15 by RouterOS 5.14
# software id = I5JN-MNY5
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d \
    tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment="default configuration" disabled=no \
    protocol=icmp
add action=accept chain=input comment="default configuration" \
    connection-state=established disabled=no in-interface=ether1-gateway
    connection-state=related disabled=no in-interface=ether1-gateway
add action=accept chain=input disabled=no in-interface=vlan.10
add action=accept chain=input disabled=no in-interface=vlan.12
add action=accept chain=input disabled=no protocol=igmp
add action=accept chain=input disabled=no protocol=udp
add action=accept chain=forward disabled=no protocol=udp
add action=accept chain=input disabled=no in-interface=ether1-gateway
add action=drop chain=input comment="default configuration" disabled=no \
add action=masquerade chain=srcnat disabled=no out-interface=IPTV-Internet
add action=masquerade chain=srcnat disabled=no out-interface=vlan.12
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
[admin@MikroTik] > /interface print detail
 0     name="ether1-gateway" type="ether" mtu=1500 l2mtu=1598 max-l2mtu=4074
 1  R  name="ether2-master-local" type="ether" mtu=1500 l2mtu=1598
       max-l2mtu=4074
 2     name="ether3-slave-local" type="ether" mtu=1500 l2mtu=1598
       max-l2mtu=4074
 3     name="ether4-slave-local" type="ether" mtu=1500 l2mtu=1598
       max-l2mtu=4074
 4     name="ether5-slave-local" type="ether" mtu=1500 l2mtu=1598
       max-l2mtu=4074
 5     name="vlan.10" type="vlan" mtu=1500 l2mtu=1594
 6     name="vlan.12" type="vlan" mtu=1500 l2mtu=1594
 7     name="IPTV-Internet" type="pppoe-out"
[admin@MikroTik] > /ip route print detail
 0 ADS  dst-address=0.0.0.0/0 gateway=194.65.169.237
        gateway-status=194.65.169.237 reachable via  IPTV-Internet distance=1
        scope=30 target-scope=10
 1 ADC  dst-address=192.168.2.0/24 pref-src=192.168.2.254
        gateway=ether2-master-local
        gateway-status=ether2-master-local reachable distance=0 scope=10
 2 ADC  dst-address=194.65.169.237/32 pref-src=188.83.116.35
        gateway=IPTV-Internet gateway-status=IPTV-Internet reachable
Does the IPTV use DHCP or PPPoE?
PPPOE is for the internet connection that goes through VLAN10.
IPTV uses DHCP in a network 10.* that goes through VLAN12.
The Internet connection is working fine , i just cant get a DHCP lease from VLAN12.
I found the problem.
It seems my ISP requires Option 60 to be configured in the DHCP client.
It has to send a Vendor-class-ID or it wont make an IP Offer.
Does anybody have an Idea if this option is available in RouterOS DHCP Client?
I see you already posted in this thread.
http://forum.mikrotik.com/t/dhcp-client-option-60/42472/1
Yes , i did , its back to the drawing board for me … I thought Mikrotik was the answer to my issues with my ISP’s router:)
Well , looks like i’ll have to wait.
