i new in MikroTik world i would like to connect my router for use with my modem, i have dynamic ip,
i have found some samples with scripts but i want to know by using Winbox setup for understand what i doing.
What i want is connect the port1 to the modem and the port2 to the switch, i have por2 have a dhcp server.
Any one can send me in the right direction for does this simple task?
Thanks for your help ![]()
You might want to do a few tutorials on the net so that you can get familiar with the platform.
This wiki should help you out with your current problem: http://wiki.mikrotik.com/wiki/Manual:Initial_Configuration
thanks for your i will read that guide.
Thanks ![]()
